Display the amount of memory used, memory available, and the number of files for internal flash memory.
5320 Series and 5420 Series support 512 MB of flash memory but only 390 MB is available for use.
- Select File System.
- Select the Storage usage tab.
Storage Usage Field Descriptions
Use the data in the following table to use the Storage Usage tab.
Name |
Description |
IntflashBytesUsed |
Specifies the number of bytes used in internal flash memory. |
IntflashBytesFree |
Specifies the number of bytes available for use in internal flash memory. |
IntflashNumFiles |
Specifies the number of files in internal flash memory. |
UsbBytesUsed |
Specifies the number of bytes used in USB device. |
UsbBytesFree |
Specifies the number of bytes available for use in USB device. |
UsbNumFiles |
Specifies the number of files in USB device. |
